舊 2004-09-13, 12:25 AM   #1
jason0412
jason0412 的頭像
註冊日期: 2004-04-07
文章: 790
車型: BMW e39 530i
e39想diy裝擴大機
e39想diy裝擴大機,請問不動原主機,那信號如何捉出來,是從主機或從後面裝換片機的地方捉出,請賜教!!
jason0412 目前離線   回覆時引用此篇文章
舊 2004-09-13, 01:01 AM   #2
文章: 21,929
e39想diy裝擴大機
最簡就是從喇叭的地方..!
用一個轉換器..就可以將high pass轉low pass了...
這是最簡單的方法..!
舊 2004-09-14, 01:35 AM   #3
Anakus
註冊日期: 2004-05-31
住址: 北市信義
文章: 3,131
精華: 4
e39想diy裝擴大機
[這篇文章最後由Anakus在 2004/09/14 01:52am 第 2 次編輯]
車款:2000年 540i  音響:DSP system
接頭線路說明:
15 pin 接頭 :
腳位 - 連接說明
1- Sub 1 +
2- Sub 2 +
3- LH Rear loudspeaker + (Touring LH rear speaker ground)
4- Radio on/antenna signal
5- RH rear loudspeaker + (Touring RH rear +)
6- Sub 4 -
7- Sub 3 -
8- Terminal 30 connects to Fuse 56
9- Sub 1 -
10- Sub 2 -
11- Touring LH rear +
12- Touring RH rear -
13- Sub 4 +
14- Sub 3 +
15- Terminal 31 connects to Ground Point
18 pin 接頭 :
腳位 - 連接說明
1- Not used
2- Low freq. negative (-) signal - Transceiver/charging electronics
3- Not used
4- Not used
5- I-bus Signal Line - Splice X18344
6- Not used
7- Not used
8- RH front speaker - Connects to Radio
9- LH front speaker - Connects to Radio
10-Not used
11 Low freq. voltage (+) signal - Transceiver/charging electronics
12-Not used
13-Telephone mute signal - Transceiver/charging electronics
14-Not used
15-Telephone ON signal - Transceiver/charging electronics
16-Not used
17-RH front speaker + - Connects to Radio
18-LH front speaker + - Connects to Radio
26 pin 接頭 :
腳位 - 連接說明
1- LH front woofer +
2- LH front woofer -
3- Not used
4- RH front mid-range -
5- LH front mid-range +
6- Not used
7- Not used
8- Not used
9- RH front mid-range +
10-LH front mid-range -
11-Right rear mid-range speaker/tweeter +
12-RH front tweeter +
13-RH front woofer +
14-LH front tweeter +
15 LH front tweeter -
16-Left rear mid-range speaker/tweeter -
17-Not used
18-Not used
19-Left rear mid-range speaker/tweeter +
20-Not used
21-Not used
22-Not used
23-Not used
24-Right rear mid-range speaker/tweeter -
25-RH front tweeter -
26 RH front woofer -
希望對你有幫助! ^^
如果你要DIY.......建議你先多了解並確定需求,再一次改好!!
推薦一個不錯的....汽車音響評比網站.... :em18:
推薦一個不錯的....汽車影音器材網站.... :em18:
Anakus 目前離線   回覆時引用此篇文章
舊 2004-09-14, 09:17 AM   #4
小毛
註冊日期: 2003-02-19
住址: BMWCCT北區團隊
文章: 5,673
e39想diy裝擴大機
我是從後面原廠擴大機音源輸入部分把訊號接出來用的
小毛 目前離線   回覆時引用此篇文章
舊 2004-09-15, 09:26 PM   #5
阿文
註冊日期: 2002-10-14
住址: 彰化-台中
文章: 284
e39想diy裝擴大機
下面引用由小樂2004/09/13 01:01am 發表的內容:
最簡就是從喇叭的地方..!
這是最簡單的方法..!
去汽車百貨找找看,有的有再賣現成的,買回來直接從原來主機接喇叭的線一接就好了,完整度高又方便.(不是每家汽車百貨都有喔~~!!)
阿文 目前離線   回覆時引用此篇文章
所有時間均為台北時間。現在的時間是 03:46 AM
