e39速度表
請問e39輪速表感應是在哪一輪呢?
我也想知道...
It is worth noting that certain failure modes are associated with particular corners of the car. If the speedometer and odometer do not work, the driver's side rear sensor is probably bad. If the speedometer works but the cruise control does not, then the passenger side rear senor is probably bad.
國外網查了一下:在駕駛這邊的後輪處 |
車內時速表嗎?是左後輪沒錯!原廠一條4~5千副廠1千多至3千多都有!
如果是速度表不走還亮防滑燈. 除了感應線壞掉外, 還有可能是電腦掛點.
| 所有時間均為台北時間。現在的時間是 06:22 PM。 |
