A/C 冷氣保險絲燒毀
行駛途中發現冷氣突然停止
冷氣面板疑似斷電 經查發現A/C 冷氣保險絲#48燒毀 更換後恢復 請教神人前輩是否須查修相關電路 網路上爬文有發現技術通報如下 TSB: SI B 64 08 06 Fuse #48 IHKA Released 31 May 2006 The fuse could be blowing due to a cut or chaffed wiring harness; shorting #48. Inspect the wiring beside the driver's knee area between the instrument panel and IHKA housing. Also, inspect the harness around the glove box (sharp edges), the water control valve, aux. water pump and between the fuse box and IHKA module. Make sure the connector isn't loose; leading to high resistance. 目前懷疑 IHKA 問題 (貴.....) 下雨天"某"相關線路脫皮造成短路(不知從何查起....) |
| 所有時間均為台北時間。現在的時間是 07:22 AM。 |
