舊 2008-04-12, 02:16 PM   #1
lukepeng
註冊日期: 2007-02-09
住址: 竹北
文章: 232
車型: E90 323i
[討論]E90 OBC 隱藏function有人找到嗎?
小弟在E90post找了很久似乎都沒有,倒是找到M5的,各位大大有試過嗎?[br][br]-=-=-=-=- 以下內容由 lukepeng2009年02月12日 05:29pm 時新增 -=-=-=-=-
經過一年....沒人回答
不過終於E90POST找到了
請大家去E90POST收尋吧
total manu
01.00 FGSTNR = "Fahrgestellnummer" (Chassisnumber) = VIN
01.01 K-ZAHL W/T = specification to dash/instrument
01.02 BMWTNR BMW = part no. of dash/instrument
01.03 COD DIA = index for code and diagnosis
01.04 KI HSTL DATUM = "Herstellungs Datum" (dash/instrument manufactured/assembled on date...)
01.05 ???= Hardware hex no., probably version
01.06 SW = same for software
01.07 KODIERDATEN = data of instrument coding
01.08 CAN (no idea)
02.00 KI TEST = Dashbord test. All light, gauges, displays and so on will light up,
move.... works only when the engine is NOT running.
03.00 ??? (maybe it will show something after your first ';service';, motoroil change) unused as yet
04.00 MOM VBR = actual fuel consumption
04.01 RW-VBR-MOM = fuel conspt per hour
04.02 = avrg fuel conspt since last reset
04.03 = distance used for calculation of avrg conspt
04.04 = avrg fuel conspt present trip
04.05 = seems pretty close to 04.03 but different start point, probably 03 = since last reset, 05 = present trip
05.00 = average fuel conspt used for calculation of mileage left
05.01 = present mileage left
06.00 how much you have in your ';tank'; in liters. Left- and Right compartment and Total
06.01 dito in hex? no, overall fuel left in tanks as shown on dash
06.02 = seems to be electrical resistance of fuel level meters in Ohm
07.00 KTMP-MOM = Temp. Cooling Fluid (celcius)
07.01 ATMP-MOM = "Aussentemperatur" Temp. Outside (celcius)
07.02 dito in hex? could be
07.03 N-MOT-MOM = RPM
07.04 N-VWF-MOM = max. RPM at the moment. E60 it gives a value. E90 it shows "-----"
08.00 V-EFF = exact speed
08.01 V-ANZ = "Anzeige" speed shown on dash..
08.02 V-SZ photo says "invalid" (?)
08.03 D-GESCHW 1 WEG = avrg speed since last reset
08.04 D-GESCHW 1 ZEIT = time used for calculation of 08.04
08.05 D-GESCHW 2 WEG = avrg speed present trip
08.06 D-GESCHW 1 ZEIT = time used for calculation of 08.05
09.00 Voltage
10.00 KM/WOCHE = distance/week, dunno how that helps
11.00 has to do how the time will be displayed (= 12/24 hr display)
11.01 km or miles
11.02 Celcius or Fahrenheit
11.03 how to display fuel consumption. km/l or l/100km or mpg
12.00 V-ANKUNFT = speed at arrival time 12.01 ANK-ZEIT = time of arrival
13.00 AUDIO = test all warning sounds
14.00 FS EINTRAEGE = error messages (if any)
15.00 Oil temp?? in hex
16.00 Dashbord lighting.
17.00 Temp inside in the car??
18.00 CC-TEST = you can see some of the ';check control'; messages.
19.00 UNLOCK
20.YY to 23.YY ??? 20 = correction factor for fuel conspt.
21 = reset dash. Keep fingers off.
22 and 23 not used.
lukepeng 目前離線   回覆時引用此篇文章
舊 2009-02-12, 05:31 PM   #2
lukepeng
註冊日期: 2007-02-09
住址: 竹北
文章: 232
車型: E90 323i
有興趣的大大可試試
舊 2009-02-12, 05:40 PM   #3
Boxy
註冊日期: 2006-01-10
文章: 4,008
贊助: 2009 2010 2011 2012
這個跟 E46 E39 E38 都一樣, 不同的是19.0 有一個密碼, 密碼是車身後五碼數字的總和 ~
Boxy 目前離線   回覆時引用此篇文章
舊 2009-02-12, 05:53 PM   #4
steve156
註冊日期: 2007-04-28
嗯嗯 E66也是這樣按的
steve156 目前離線   回覆時引用此篇文章
舊 2009-02-22, 01:21 AM   #5
lukepeng
註冊日期: 2007-02-09
住址: 竹北
文章: 232
車型: E90 323i
小弟在用07項目中看冷卻水溫發現溫度會跳來跳去
有時100~105C, 有時80C, 去E90POST收尋有人說是因為N52引擎
有分三段控溫,照不同開車激烈度調整水溫
請問真有這樣的功能嗎? :em14:
舊 2009-02-22, 08:37 AM   #6
chi0939
註冊日期: 2007-03-05
住址: 新北市 永和
文章: 132
車型: e90 320i
下面引用由lukepeng2008/04/12 02:16pm 發表的內容:
-=-=-=-=- 以下內容由 lukepeng 在 2009年02月12日 05:29pm 時新增 -=-=-=-=-
經過一年....沒人回答
不過終於E90POST找到了
請大家去E90POST收尋吧
total manu
還是看不懂如何進入功能鍵
可否請大大用中文說明如何進入或操作
謝謝^^!
chi0939 目前離線   回覆時引用此篇文章
舊 2009-02-23, 03:40 PM   #7
Boxy
註冊日期: 2006-01-10
文章: 4,008
下面引用由lukepeng2009/02/22 01:21am 發表的內容:
有分三段控溫,照不同開車激烈度調整水溫
請問真有這樣的功能嗎?
沒錯~ E46 年代就是這樣了~ 開的越用力轉速越高溫度應該要越低~ 避免爆震~
一般使用時溫度較高, 此為為了增加燃燒效率, 節能省油~
Boxy 目前離線   回覆時引用此篇文章
舊 2009-02-24, 05:29 PM   #8
lukepeng
註冊日期: 2007-02-09
住址: 竹北
文章: 232
車型: E90 323i
下面引用由chi09392009/02/22 08:37am 發表的內容:
還是看不懂如何進入功能鍵
可否請大大用中文說明如何進入或操作
謝謝^^!
1). 按里程歸零鍵15sec
2). dash board會出現01.00項目編號,下面有一組數字五碼請自行加總
3). 在01.00項目中再按歸零鍵2秒會變為 01.__,請開始按按按到19.__
4). 過大概一秒變為19.00 CODE LOCK CODE 01
5). 趕快開始按按到您的總和CODE XX就停下
6). 19.00項目就變為 CODE UNLOCK
7). 按歸零鍵兩秒19.00變19.__
8). 在開始一次一次按歸零鍵到你想看的項目停下該項目會變為XX.00後
再一次一次按到子項目 ,例如07.01, 07.02等等
再不會請自行參考E90POST
舊 2009-02-24, 05:33 PM   #9
lukepeng
註冊日期: 2007-02-09
住址: 竹北
文章: 232
車型: E90 323i
下面引用由Boxy2009/02/23 03:40pm 發表的內容:
大大真是BMWCCT之神啊,
小弟在E90POST苦海中浮浮沈沈
在這裡問大大還比較快ㄌㄟ
舊 2009-02-24, 06:01 PM   #10
Boxy
註冊日期: 2006-01-10
文章: 4,008
下面引用由lukepeng2009/02/24 05:33pm 發表的內容:
大大真是BMWCCT之神啊,
小弟在E90POST苦海中浮浮沈沈
在這裡問大大還比較快ㄌㄟ
您這樣說小弟完全無法接受 CCT 之神小弟連排隊都沒得候補~
E90 上面有很多有趣的資訊, 小弟偶爾也會上去翻一翻~ 其他也建議您可晃晃E46 Fanatic 的E90 section, 裡面有較多專業的車友PO 文歐~
Boxy 目前離線   回覆時引用此篇文章
舊 2009-02-25, 12:59 AM   #11
BRABUS
BRABUS 的頭像
註冊日期: 2003-12-24
住址: 高雄市∼灣仔內
文章: 3,528
下面引用由Boxy2009/02/12 05:40pm 發表的內容:
E39怎麼按?
BRABUS 目前離線   回覆時引用此篇文章
舊 2009-02-25, 01:15 AM   #12
Boxy
註冊日期: 2006-01-10
文章: 4,008
1.開到第一段/第二段/發動都可
2. 長按里程歸零桿
3. 等里程數那變化成1.0, 立即放掉按到19.0
4.等顯示"lock_off" 時再短按一下
5. 按到你需要的menu (最常用的是7.0 - 水溫)
熄火關電源後或按到19.0 選"lock_on" 恢復原本里程數功能
Boxy 目前離線   回覆時引用此篇文章
舊 2009-02-25, 01:26 AM   #13
BRABUS
BRABUS 的頭像
註冊日期: 2003-12-24
住址: 高雄市∼灣仔內
文章: 3,528
下面引用由Boxy2009/02/25 01:15am 發表的內容:
1.開到第一段/第二段/發動都可
2. 長按里程歸零桿
感謝分享~下去按按看 ! !
所有時間均為台北時間。現在的時間是 01:58 AM
